Disables port up/down trap reception for specified ports.
port_list |
Specifies one or more ports or slots and ports. |
all |
Specifies all ports on the switch. |
Enabled.
Use this command to stop receiving SNMP trap messages when a port transitions between being up and down.
The following command stops ports 3, 5, and 12 through 15 on a stand-alone switch from receiving SNMP trap messages when the port goes up/down:
disable snmp traps port-up-down ports 3,5,12-15
This command was first available in ExtremeXOS 10.6.
